Gummi Bear said:I'd say rear. But if you run across a good front locker, pick it up.
get a detroit instead of a spool, it will be much better for street driving...bigjhoov said:I was thinking the front first since I mainly drive it on the street.
That's who I was hoping would chime in. Nope, no PS, everything manual. Inline 6 and column shift too. Thanks for the info.SaddleUp said:It's pretty much a toss up. When you are off road locking the front will aid with traction due to the extra weight on the front when you are on relatively level ground. Once you start up a steep hill though the weight will shift to the back and you will lose some of that advantage. Another thing to consider is that the extra weight in front is more likely to keep both tires on the ground so it will not need the locker as often. Putting a locker in the front will effect the steering. If you have a good power steering setup then it may be liveable but you will still notice it. I would probably lock the rear first. Then I would try to find a selectable locker for the front.
Technically speaking an open carrier always distributes torque evenly to both axles. (This will confuse some but the result is that when one tire loses traction then there is no torque to that wheel and in turn the other doesn't get any torque either) Open Diffs do not put as much stress on parts, help prevent slipping on ice and packed snow, and they help hold traction when side hilling. They are also easier to steer. Selectables provide the best of both worlds because you can choose when to use it as an open carrier or as a spool. In a real challenging situation having this option can make the difference between success and failure.green69 said:i have never under stood keeping an open diff what is the purpose?
SaddleUp said:Do you still have a Dana 30 in front? If so then I definately would not put any money into it for a locker. Keep it open and hope it lives long enough to find a Dana 44 to replace it with.
