trentturner27
- Sep 25, 2011
- 82
i have the cable operated floor shifter for the 4r70w. i have been messing with this on and off for over a week and im starting to get frustrated. the first issue i was having was clearance issues with the transmission shift arm and cable bracket with the front drive shaft. the instructions say to mount it to the pan bolts but i don't think that will clear at all. then i read where a couple guys used the two bosses just to the rear or the arm to mount the cable. that took care of the cable being in the way. i noticed how long the lokar arm is and i feel it will be too close to the driveshaft so i tried to reuse the factory explorer arm. i got everything lined up good and started trying to adjust everything so the shifter and trans were in sync. i think the arm on the trans is too short or cable is coming in at wrong angle or someting. if i set them in sync in neutral the transmission will get to park and first before the shifter will. i guess im going to drop the pan and install the lokar arm but im concerned about driveshaft clearance when suspension is compressed. if anyone has installed this shifter i could really use some advice. some pics of how the cable is on the transmission and how the shift arm is clocked would be great too. hope that made sense... thanks a lot
