Looking for pics of Lokar’s 6R80 (or other similar floor shifters) shifter installed in a Bronco
WPS 73 Bronco
The Woodlands, Tx
I want to see how the surface mount sport shifter install looks. Did you build a console box around it to hide the bottom of it?
Lets see some interior pics. How did you dress it up?
WPS 73 Bronco
WPS 73 Bronco
The Woodlands, Tx
I changed the title to include other similar examples. What I'm really looking for are pics of how you've added a console or something else around the shifters to make it look good.
Howard2x4x4
Similar circumstance, with an added twist...... C4 tranny, easy enuff, but I went with a 1987 F150 tilt steering coloumn, so that muddied the water a bit. I also wanted to ditch the foot pedal e-brake because - well, just because. And I wanted a center console because, well, just because. I did buy a Pinto hand e-brake figuring I'd flesh it out eventually, but I switched course.
Instead of fleshing out the Pinto e-brake' I started wandering thru pick-n-pulls for something Ford that was closer to what I had in mind. Found a Ford model with a console mount shifter and e-brake. So far so good, but the console mount late model shifter didn't want to play nice with the vintage C4. Made another course correction and picked up a Pinto/Mustang II C4 console shifter and bezel and a hand e-brake lever from the late model p & p Ford. Had to elevate the shifter and e-brake a bit to accomodate the console. 20240113_101101.jpg Fabricated the e-brake and shifter mounts and a bracket to hold the shift cable. 20240113_110550.jpg Had to modify the console a bit because Ford apparently didn't plan it going in an EB. No big deal, just need some plastic paint to pretty it up a bit. 20240113_110752.jpg Put a few of the factory pieces and parts back together, and the C4 bezel in place. 20240113_135400.jpg The shifter bezel adds a nice period look, imho. The tranny shift knob, TC shift knob, and the heated seat switches still need tweaking, as does the radio. 20240113_135432.jpg The shifter knobs are windshield knobs I bought used on Ebuy. They match the instrument panel knobs. Had a machinist buddy modify one to go atop the Hurst shifter I'm using for the TC. Still need to get a vision for the C4 shifter knob. Where there' a will, there's a way.
Gotta fine tune some knobs, and configure the TC shifter, and get the radio installed somehow. One day at a time, one project at a time.
Howard in beautiful and blizzardy and blustery west Michigan.
anoblefox
all shaft operated, only a 5/8" hole through floor; no cables
Colo77Bronco
Colorado Springs
Really smart! Seems like cable mounting bracketed is the biggest challenge with 6r80/10R80 in our rigs with the limited space in that area especially with an Atlas. Many go back to column shift because a solid linkage doesn't need additional bracketry. You may have saved me a ton of time!
nvrstuk
PNW
Pics of what you ended up with?
I run a Winters, custom console that I mated with my 20 yr old Tuffy, cable shifters and a ProCase (Atlas externals). My shifter cable comes in from the front.
WPS 73 Bronco
WPS 73 Bronco
The Woodlands, Tx
Here's where I ended up. Dan Carr custom console with Lokar ss shifter and JB twin shifter, both cable drive to a 6L80 and AS Atlas TC. It's designed to mate up to my existing Tuffy console.
idus25
St. Louis
Instead of fleshing out the Pinto e-brake' I started wandering thru pick-n-pulls for something Ford that was closer to what I had in mind. Found a Ford model with a console mount shifter and e-brake. So far so good, but the console mount late model shifter didn't want to play nice with the vintage C4. Made another course correction and picked up a Pinto/Mustang II C4 console shifter and bezel and a hand e-brake lever from the late model p & p Ford. Had to elevate the shifter and e-brake a bit to accomodate the console. View attachment 917160 Fabricated the e-brake and shifter mounts and a bracket to hold the shift cable. View attachment 917161 Had to modify the console a bit because Ford apparently didn't plan it going in an EB. No big deal, just need some plastic paint to pretty it up a bit. View attachment 917162 Put a few of the factory pieces and parts back together, and the C4 bezel in place. View attachment 917163 The shifter bezel adds a nice period look, imho. The tranny shift knob, TC shift knob, and the heated seat switches still need tweaking, as does the radio. View attachment 917164 The shifter knobs are windshield knobs I bought used on Ebuy. They match the instrument panel knobs. Had a machinist buddy modify one to go atop the Hurst shifter I'm using for the TC. Still need to get a vision for the C4 shifter knob. Where there' a will, there's a way. View attachment 917166
Can you show me how you connected to 6R80? Have atlas 2 and the Lokar bracket seems really close to the front yoke. Thanks.
