Long Arms
needabronco
Prescott/Farmington
After many delay's I'm almost done with my extended radius arms. I still need to install the shock mounts, but you get the picture. What do you think?
73stallion
Eugene, OR
looks real good! what's the life expectancy of johnny joints as compared to heim joints? i know the johnny's can be rebuilt.
needabronco
needabronco
Prescott/Farmington
I believe they last quite a while. Lars Pederson designed them about 5 or 6 years ago, and several sets (that he made) have been thoroughly abused and no joints that I know of have ever been rebuilt.
Just about every jeep suspension system uses Johny Joints, well except for Rubicon Express. They are even used on 3/4 ton suspension systems.
garberz
Bronco Influencer
Conejo Valley, Ca.
How much longer are they? What are you using for, mounting to the frame?
How many degrees did you bend them for tire clearance? They look great. I want to make a set.
needabronco
needabronco
Prescott/Farmington
Thanks for the compliments.
I 'may' produce a small run of them, but holy-moly there alot more work than they appear.... They are approximately 6" longer than stock, everything is 1/4" where 'beef' is even a question. In fact the only part not 1/4" is the plate over the end of the 'C'. The frame bracket is of coarse 1/4" also.
On a side note, they add approximately 1 degree of caster, and as an experiment I'm going to run them on a stock suspension for a couple of weeks or so just to see how they work out. I'll be sure to post up how much more flex I'm able to get out of the stock setup for comparison.
Doyle
Looks good, how about some more details for those who'd like to duplicate. I've got a spare set of stock arms, a sawzall, side grinder, die grinder and a welder. What else do I need?
burntfish
ouray, co
Looks good. How much longer then stock are they. "They are right approximately longer than stock"
bax
Old Member
Your bends are near the back of the arm? Wont this put the arm in the way of the tire more than the ones with the bend near the front?
needabronco
needabronco
Prescott/Farmington
Dack, they are 6" longer, sorry about that...
Bax the bend in the arms is right where the stock radius arm would attach to the frame, so they do not directly affect the turning radius. Other brands of arms bend near the head and effectively do the same thing.
The mount is moved farther back, but the arms are 'short' enough that they do not contact the frame at full stuff like some longer arms are supposedly known to do. This is in sorts a 'compromise' between longer super flexible arms, and stock 'stability'. They do ride great on the street, don't feel 'tippy' at highway speeds like some other brands yet still flex much better than stock arms.
Doyle unless you know someone that can bend 2" .250 wall DOM, you'll also need a tube bender... If you want to make your own research 'Lars bars' on pirate4x4. If your interested in a set and aren't in a huge hurry, let me know. I might be able to help you out.
bax
Old Member
OK, I understand I thought the arm was longer than 6'' longer.
BroncoBoy72
Marana Arizona
Doyle unless you know someone that can bend 2" .250 wall DOM, you'll also need a tube bender... If you want to make your own research 'Lars bars' on pirate4x4. If your interested in a set and aren't in a huge hurry, let me know. I might be able to help you out.[/QUOTE]
I had to make my radius arms and lower links on my bronco out of 2.25" .375 wall DOM due to I bent the crap out of 2.0 .250 wall, not bragging just say it is possible and has been done.
broncokak
I'm interested in this type of arm too. Can you post a picture of the frame bracket by chance? TIA
Broncoholic1
I just clicked off Cage's site. $745 is a little much, they hit the frame without a radius arm drop. I would like a set PM me. Plez show picts of the bracket, how much drop?
Doyle
Don't have access to bender that would handle tube that size. Price for complete package? How long a wait? Have you considered cutting, bending, slotting tubing and selling a fab kit? A kit would be less work on you and make shipping costs a lot lower. You could even offer it with or without the Johnny Joints and frame brackets if you wanted.
needabronco
needabronco
Prescott/Farmington
Here's some pic's of the brackets. Not mounted yet, but you get the picture.
Doyle I'll think about the 'kit' form, although it takes alot profit out of the equation, it would simplify my process and time.
Doyle
Frame brackets look plenty stout. Let me know when you get a line on pricing and availabilty, kit or complete. I'm interested, just not sure about budgeting till I have some figures.
