Looking for E-Brake system-hand brake style
Goody
Pensacola, FL.
My e-brake is a mangled mess and hooked to a random spring underneath when I purchased truck. Instead of the foot brake system (which I would need practically every piece minus the pedal), I was hoping someone has some experience w/ a hand brake setup that’s moderately easy to install! I’ve got most of the tunnel cut out now for a NV4500 install and should have plenty of room on the passenger side of new fab’d tunnel. Initial thought was something out of a Fox body or SN-95 mustang, w/ a custom boot to cover mechanism or change the angle some and submerge in tunnel cover... I know they make an electric actuator for this now but that’s more than I wanna spend, I’m sure.
toddz69
Your Fox Body Mustang idea is exactly what my dad did to ours back in the 80s. It's worked well with the various rear brake setups I've had over the years (currently Explorer discs). He build a little subframe on the underside out of angle iron for the cable stops, etc. His initial boot was hand-stitched out of vinyl. I replaced it years later with one from a 5-Series BMW that I found in the junkyard.
Todd Z.
Goody
Goody
Pensacola, FL.
Todd Z.
Jackpot! Thank You Sir! Was also given the idea of using a setup out of a Jeep Cherokee. I’ve got options now! Sub-frame setup would be a must b/c I tend to hulk things daily!
chrlsful
stick/button release style e-brake upgrade
Todd Z.
Any pic? top side'n underneath?
No need to answ this: Wonder how a 'line loc' might interact w/this system (pull e-brke & have line-loc up frnt or the reverse). Just playin w/ideas on a 'wrking' not rec bronk...
Bronco2EB
Knoxville, TN
Lokar sells a "universal" hand e-brake that could be used. I'v only seen it used a couple times in a Bronco though, but i'm sure one of their techs could help ya out to see if it may be a good route to go.
chrlsful
Thanks for the post-back !
yes they do but I can aquire similar at the yards for well less than 100 - 150$
My needs flow along the design. If some1 else has developed that - I just copy...
8^ )
I can get cable, even swage a ball on the end...where/what could I use to 'change direction' a garage door pulley? Would it B beddah to have a straaingt run (new position) such as right offa the tunnel (as suggested)? It's a fun project but 1 that's only briefly crossed my mind.
I don't like the foot/hand nature of the oe's.
"...room on the passenger side of new fab’d tunnel..."
unlike Goody, I have the PTO shift to contend with, "left hand" might B nice...
Goody
Goody
Pensacola, FL.
I think Lokar makes a variation of the type e-brake you are wanting.
Checked this setup out! It will fit what I’m looking for perfectly, in my mind at least! Riv nut some drilled out brake line holders to the cross supports on the floor and cut to fit! Thanks for the heads up! For some reason when I was on their site a few days ago researching throttle cables, I failed to see them! I can pop $250 from Summit for handle mechanism and cables. Drop in the hat here lately!
abn373
Charleston, SC
I posted this elsewhere. But I made a similar set up from some hardware store turnbuckles and angle iron for a few bucks and then got and already pulled handbrake from a 80s Cavalier from a junkyard. I bet my whole set up was under $100 and you can adjust the tension by simply unapplying the handbrake and duck under and adjust the turnbuckle to your liking. I like the handle set up. I don't use a boot, but would be easy to fab it into a console or boot.
chrlsful
"...Checked this setup out!,,," What set up? I don't C an example...
abn: the turnbuckle was not something I thought of. Looks promising (top AND underneath!). Center of tunnel is great (if it fits w/my NV tranny & single transfer 'sticks'). Can U tell me how much reinforcement is on the bottom of the tunnel to support the 'handle'? Again - my NV is pretty close to (underneath) there...
Thnx~
abn373
Charleston, SC
Thnx~
The handbrake I used has a very small foot print for the OEM (GM) bracket on the top, probably 3"x4". I just bolted it to the floor with some fender washers underneath. then put a small piece of L iron to the rear of the bracket to act as the holder for the cable (just like underneath). I didn't need to reinforce the tunnel at all AND I have old school Kentrol fiberglass tub and it has been fine since 1999 and I set the brake every time I stop. If you have a steel tub I can't see having a problem because mine is at an unreinforced section of the FG tub with just fender washers.
Oh and my cable goes through the floor way back under the center console. I have it on a spacer so the Ebrake and Winters floor shifter cables go underneath before exiting the floor.
abn373
Charleston, SC
Best part is, and the reason I did it, is if you have a hydraulic brake failure even at interstate speeds, assuming you don't have to immediately stop for traffic, you can pull that and it pulls the rear drums evenly and as long as you keep your thumb pressing the button you can slowly apply and release brakes as needed to bring yourself to a safe stop. Hell, better than stomping the OEM foot brake I figure. ?:?
chrlsful
purdy slick.
"...keep your thumb pressing the button you can slowly apply and release brakes as needed to bring yourself to a safe stop...."
just Y I don't like the OE (plus the hand/foot involvement).
This is good as there's no re-direct of the cable (cept the space ofa thin sheet metal 'tunnel') as would B if placed forward of the driver.
At least 1 last Q:
The 'button" on eacha these wrk a lill different. Some have a big 1/4 wheel w/teeth . How duz the Cavalier wrk? (just an internal peg dwn to the foot or base?).
This 'look like it' (4 ya) Goody ?
So far seems 2 fit my 'plan'.
(like to C 1 @ the left hand/under dash tho, just haven't figured on the axel mount 4 that garage door pulley or 2. Also cable might not play w/the aux tank so well).
fordguy
also look at old beetle/vw hand brake. they are slick and inexpensive.
chrlsful
veedub hand break
I thought 'pricy'. How to obtain 'for less'?
No junk yrds have'm here as everything 10 yrs + go to the crusher...
abn373
Charleston, SC
Yes, the Cavalier handle is one of those half wheel types with about a dozen teeth and it ratchets up. If you were using it for emergency braking, the top button being held in keeps the paw from catching any teeth so you can move it back and forth freely.
I don't recall having to do much, if anything to the mount to bolt it to the floor. I maybe bent one of the legs flat or something but it was pretty much bolt it to the flat floor.
I didn't go to the junkyard looking for a specific handbrake, just asked if they had any pulled and they directed me to a shelf with a pile of various handbrakes that were pulled and this one seemed the easiest to not have to modify.
chrlsful
thanx fordguy.
I think the link shows 1 that still needs the prt the rachet engages in, a base plate'n such.
Will go to JC W. 4 a look. They were the #1 discounter so not of quality in the ol daze. Let's C what they got...
chrlsful
Mud yer a Stud !
U filled out the search function 4 dis fumble fingers!
Never knew there's a write up just waitin.
Thnx !
More options 4 the welder'n scrap round here.
Gettin real close now, hotter'n hotter'n hotter...
