So...I picked up my Bronco about 18 months ago. My rig had a restomod done by a previous owner back in 2010 (undercarriage/engine bay is date stamped 2010). However, that owner passed with most of the records regarding any mechanical upgrades he did. I purchased the rig off of the next owner (who essentially flipped it…guessing he picked it up for peanuts and sold it to me).
I’ve recently been looking into putting some $$$$ into my existing setup and struggling with which direction to go in. Engine runs OK now, but feels sluggish. I feel like I should have more power than I do.
I have been thinking of adding EFI (rig is a driver/cruiser and will occasionally see some light trails), but I’m not sure if I should stick with Ford EEC-V or just go aftermarket? Would one EFI system work better with my setup over another…
Also thinking of modifying the exhaust system with headers, but if I add a new exhaust now will I have issues installing a 4r70w down the road?...or can I just modify that when I make the switch.
Do I need to figure out the unknown engine parts (ie cam) before making a decision on which direction to go with my rig?
I attached a couple pics of the engine as well.
This is what I know about my setup:
Block: stamped E7TE - '87 roller ready block (I believe)
Bore: Unknown
Recent cold compression test: each cylinder was between 120 and 140
Firing Order: 351
Heads: AFR 165s (58cc)
Cam: Unknown
Carb: Edlebrock 500 cfm – Model #1403
Intake: Aluminum Edlebrock intake
Front Dress: Mustang setup (I believe)
Trans: C4 (rebuilt since I have owned, so married to C4 for a bit)
Transfer Case: Dana 20
Gears: 3.50 LSD
Dana 44 up front
Exhaust: Manifolds and 2 into 1 exhaust/muffler/Cat (no idea what muffler is on their…no identification on there that I can see)…guessing it is not anything special.
Tires: 33 / 12.5 / 17
Thanks!
JB
Bore: Unknown
Firing Order: 351
Cam: Unknown
Gears: 3.50 LSD
Dana 44 up front
Thanks!
JB
