loose door panel help
mlaird
Houston,TX
the top part of my driver side door shell has some major flex in it. every time i shut the door or hit a bump in the road the mirror shakes big time. the top of the door shell(where the mirror mounts and along the glass channel) seems to be really flexible for some reason. has anyone else experienced this problem or know how to fix it?
Explorer
Raphine, Virginia
Probably rusted and poorly repaired. Roll up the window, take armrest, door latch and window crank off, remove panel and you can reach the backside from there. Stripped screw hole's can be fixed by bolting on the mirror. But that's pretty thick metal, shouldn't be flexing.
