Luber body mounts Poly vs. stock rubber
benelibutton
Im about to replace mine and the ride of the bronco is way more important to me then then strengh because the bronco is 75 percent street and 25 percent trail. If the rubber is a smother ride I would prefer them. Which one should I install . Also thinking of putting a one inch body lift while im at it. What problems well I have to address after the install. titties
rguest3
WH 1" Body Lift Kit. Has everything you need.
Only issue would be longer adjustable clutch linkage if manual shift.
bigmuddy
Marthasville Missouri
Personally, your ride quality will be determined by the springs and who produced them. Also my ride got tremendously more livable when I added the Cage long arms. Seats also make a big difference as well. Get a good suspension seat and you are miles ahead.
I don't think I could tell the difference between poly vs rubber on and the difference in ride quality as its not significant IMO. You will get more vibration transmitted throught the poly bushing into the cab though.
B
benelibutton
Yea I know it wouldn't make much of a diff. But if it made any that's the way I would want to go. I just got in the mail some 11 pack leafs from toms' and the rest of my lift is progressive springs from duffs. so going to install it all and hope for a way better ride.
Rguest 3 ? dose that wh 1 " body lift come with hardware and the new body mounts
rguest3
Yep, complete kit. Everything you need.
Just put one on Today when the 77 body went back on the chassis at the body shop.
Gonna need new suspension bushings. C-Bushings matched to lift, Radius Arm end bushings and leaf spring bushings. These can all be found in Kit form as well.
B
benelibutton
I just found it and ordered it. I was going to go with bc's 1" because they looked cool and metal but this kit is just to functional to pass up. Just what I was looking for. Thanks. When you put yours on did you order the clutch linkage or did you just modify your old one
rguest3
Current build Bronco is Automatic.
But my 69 is a 4-speed and has the same WH 1" mounts and I got their adjustable clutch linkage as well. Easy to install and dial in correctly.
moosebob
I installed the adjustable clutch linkage rod, along with my WH 1" body lift.
Excellent piece and not expensive at all.
