Mach I seat fitment?
oldiron
Scored a set of 2004 Mach I seats this week. Anyone use these? Any tips or tricks on installing? Pictures? I might try to do these this weekend, time permitting.
Greg
ngsd
Measure height and width and whether you are using a center console or not. If they are within your goals, Fab brackets to get it to work. Sliders are in the seats on those I believe.
With many of these modern seats, they sit really far off the floor. You may be chopping the floor out to get the seat height correct.
sykanr0ng
/\/\ This is true.
Most modern seats are power seats and the electric motor in the base means they cannot be as low as a manual seat, every late model Mustang I have found in a junkyard has power seats.
ngsd
Yes, it would be interesting if you measured them base to top and posted the difference between those and stock buckets with the base brackets s on them. how you fab the floor brackets versus how the originals are and how high you want to sit is the key. Measure and let us know what you find.
JefeAZ
Tucson
I used 2005 Mustang seats which are probable identical. They sit low to the floor but you need to use the sliders as the mounts
