So I pulled the trigger a while back on the Magnaflow dual exhaust with an X-Pipe. Just tonight I installed what I could.
As you can see, the J-hooks are too short in my opinion. I like to see 2 or 3 threads above the nuts.
The instructions say to bolt the tailpipe mount to the threaded hole in the frame... Mine never had a threaded hole. No biggie. 10 minutes per side with a drill and that was solved. Just used a longer stainless bolt and used a stainless lock nut inside the frame.
The X-pipe will not work with an NP205. It does look like it would work fine with a stock Tcase. Luckily I have a spare X-pipe that's 3" and I'll turn it sideways. That should give me the room to go around the NP205. As I'll be running fenderwells it is a good area to exit the frame.
