Theremostat was in correctly. I have been driving it for 6 months, since i last put it in. Belts are fine. How will i ever get anything blocking a passage out? I will check the thermostat tomorrow.
I was doing a search on similar problems. when i came across my own thread. last time i pulled the heater motor, smae thing happened to me. I pulled over when i niticed it was 230degrees. I turned my fan on to cool it off. Stated it back up and problem went away. Strange.
The water feeds in from the bottom coolant line in radiator? then up through the thermostat? then through the heating core? If my thermostat is closed, my core wouldn't get hot? Is this correct?
