I worked in a cabinet shop... use a gel type super glue with a aresol activator we called it "kick and stick" the minute you spray the activator it was stuck!!!
The name of the stuff we used is fastcap ;D
http://www.fastcap.com/2p10-10oz.aspx
Make sure to use the 10oz GEL BOTTLE not the tube (its the caulking gun form way too much for the avarage guy) Use the Gel formula it wont run all over... And make sure to order the aresol activator also its what makes it fast setting...What ever you do DONT GET IT ALL OVER YOUR HANDS!!! Ask me how I know.
...Works on regular particle board, regular wood, laminate, plywood, plastics(careful here some will actually melt with activator before it evaporates)and MDF for consoles and speaker boxes..
For any woodworkers you can glue huge crown molding with this stuff and get a perfect fitting mitre joint EVERYTIME before you nail it...Hint hint..
Ive also glued Steel yes STEEL together, right before you tack weld something to keep it from moving and then weld it together... its the best stuff Ive ever seen....
