Is there a MC for 4 wheel disc brakes that'll work without a power booster? I don't want to go to Hydroboost or even a power booster but the only MCs I've seen say they take more effort to depress the pedal and recommend going with the booster.
The MC is just one part of the brake system. Ultimately, the calipers don't care how you supply pressure to them to work, so long as you supply enough of it. In the 1" bore size range, a 1/16" difference in MC bore size equates to about an 11% difference in output pressure for a given input force, and a corresponding increase in pedal travel of 11% as well.
That said, the bore size of your MC should be related to the caliper piston areas of your calipers, pedal ratio and brake pad coefficient of friction. I generally try to set up manual brake systems such than they achieve lockup at less than 90 pounds of pedal force, but how you get there is up to you. Since the pedal ratio is one of the more difficult things to change without doing a bunch of fabrication under the dash, that leaves MC bore size and pad CoF. While the bore size is an easy way to gain 11-23%, you typically make larger differences with the pad compounds.
Most pads with be tagged with a hot/cold friction CoF range in the manufacturer numbers, indicating a CoF range for the pad at a certain temp. It's a letter code where E=.25 to .34, F=.35 to .44, G=.45 to .54, etc, so you'll typically see an "EE", "FF" or "GG", however some will be "EF", "FG", etc, although they usually try to keep them the same since that gives the appearance of a more linear CoF, whether it is or isn't. I prefer to run a "GG" friction rated pad in a manual installation, something like the Hawk HP Plus, EBC Yellowstuff, Carbotech AX6, etc.
From experience I recommend even smaller bore with manual brakes, I have a dual master set up and run a 3/4 bore front and 7/8 bore rear and it works very well. Brake effort is compatible to my Chevy avalanche. Very easy to stop. I do have big calipers as well though. You will notice increased pedal travel though.
Dual master cylinders with a balance beam are different since the MC's are in parallel rather than having the pistons in series like in a conventional tandem disc/disc master cylinder, so it's not really comparing apples to apples. The dual setup divides the pedal force between the two master cylinders, whereas the tandem setup does not, since the pressure from the primary piston is applied to the secondary piston. For example, the output force on (2) 1" bore MC's in parallel will be half that as a conventional 1" bore MC for the same pedal ratio and input force.
While there are definitely benefits to running a dual master cylinder setup with a balance beam, most of those benefits are specific to racing applications in my experience.
