76 NC Bronco
I have a 76 bronco with stock front disc brakes and rear drum brakes and a 2" body lift. I have seen the stainless steel brake line kits as well as all the other hard brake lines available at most of the vendors. I have not seen any lines that say they accommodate the extra length needed to go from the master cylinder to the brake proportioning valve when you have a body lift. Does anyone sell pre-bent stainless brake lines for this purpose, usually has a circle / loop in the line to absorb any movement between the body and frame, if I am not mistaken. Also, I am wondering if anyone has found a finish for a master cylinder that can withstand brake fluid without peeling or getting screwed up when brake fluid inevitably gets in contact with it. I was thinking of getting a standard master cylinder powder coated, but not sure if powder coating is the best choice, would some sort of epoxy finish be better? Thanks in advance for any help.
