Max Tire Size?
walker_creek
Everybody @ OCBR said to join up here.
I have a 3.5" WH lift with 2" body lift. I want to go up in tire size. WH says a 35" tire will fit no problem, but, can I go bigger. I'm thinking 36's might fit with a little more trimming, but the tire selection isn't very good. What would it take to cram 37's under there?
Any opinions/experience would be greatly appreciated.
It'll be a couple months before I get bigger tires, but I need to get ring & pinion sets ordered this week.
TN1776
I run 37" tires on my Bronco, but I've got a 5.5" suspension lift and 2" body lift. My front clears with no problems, but my rear will rub the inner fender/wheel well at full stuff off road. It takes a pretty extreme maneuver to get it to rub but it will rub. With 2" less lift, I think it would rub a lot more. In the rear it hits where the wheel well meets the floor, if that's any help.
BIGED
Guru ????
Welcome to the site, glad you made ocbr. I just put 37 on with 3.5 lift and 2 in body lift it rubs a little at full stuff and I have trimed all I can and spaced wheels out till I get new wheels with diffrent back space
Madgyver
Bronco Madman
Do you own a jigsaw,sawzall or bodysaw?
Cut your flares up to the bodyline and it will be fine with 37"s
Welcome to the site..
I am madgyver
Rockin69er
I have a 5.5 SL and no body lift, just new mounts. This pic is with 37x13.50x15 Xterrains and with the Cage arms. Just to let you know that with the stock radius arms my F-250 Super duty had a better turning radius.:p The taller you go after 32's the sooner you will rub on the arms. The warflares are mounted right up to the body line.
johnmlebel
i also run 36" but mine are 14.5 wide and i am cut to the line like mad's and i only run 3.5" of lift
