Just found this
Yep, the general rule-of-thumb used to be 1.5° per inch of lift, then it changed to 2° per inch. But by that time we were also realizing that most (almost every one?) Broncos had not been delivered with the called-for caster reading in the first place, so it got to the point where even with 7° bushings and only 2 to 4 inches of lift, we were finding we had a LOT LESS than desirable caster readings.
The book calls for (differs by year) from about 2.75° to 4.25° of "positive" caster. Most of us (me included) have less than the minimum even with the big bushings.
So yeah, unless you know exactly what you have, more is better. So just go big.
The only trade-off is that, the more positive caster you give it, your pinion angle goes down farther from optimal too. So far though, up to the point you're talking about, it's been a reasonable trade-off. For those with extreme cases though, like where the bushings still aren't enough to get what they want, they have to cut the outer yokes off and rotate them to achieve the desired caster. I wouldn't worry too much about that until you get it measured, but at least now you know what sometimes has to be done to get it perfect. If you come in at anything over 2° positive though, it should drive pretty well.
