When I purchased Buttercup in March of 2018, the owner told me that the mileage was 'actual' and 'original' I acknowledged the fact, but with a 55 year old vehicle, you take that fact with a 'grain of salt'. The speedo could have been broken for 100 k miles, or changed, or no telling what else.
However, Buttercup was pretty complete and I could tell it was an 'honest' survivor, so I had to have it. Once I began work on it, I found out that this U13 was much more than I had originally thought. This is a complete opposite from what I usually find with Broncos! They are usually worse than I thought!... A pleasant surprise for sure!
Usually Ford vehicles doesn't list "matching numbers" like GM, but during the engine build, I discovered the engine block code, the aluminum engine tag on the distributor bolt bracket, and the carburetor tag all have the same date codes! WOW!
Disassembling the rear brake drums, I discovered the rear drums have never been removed. They still had the thin, sheet metal drum locking nuts, which I have never seen still on a Bronco! I also found the original brake shoes front and rear!! The picture showing the brakes assembled, nothing was painted. Original paint on the backing plates and springs!
The shocks front and rear were the originals from August 65! They were not usable, but still existing!! WOW!
While removing the headlights, I noticed they are still the script headlights!! Both of them! And they still work!! "Made for Ford FOMOCO" etched on the glass!!
The little U13 still has the original tie rods and draglink and drives nice and tight!! I've decided that Greg was right and Buttercup did only have 58k miles!!
I think the oil in the engine, transmission, transfer case, and rear diff were original too!!
It sure smelled like it!! LOL... and that is probably why the engine was weak!
