Dbarnes72
I'm filling in some rust pinholes and of course it's blowing thru. Will lowering the shielding gas pressure help reduce this or is it all in speed and technique.
Don't hit it straight on and heat is what blows through. Lay your mig tip at an heavy angle (45 degree) and just do tiny spot welds until the pinhole is filled.
Abrasive flapper wheels are good to sand small welds like that smooth without grinding them away...
Don't try to fill in all at one shot. Use a series of small tack welds, and let each weld cool (not red)before the next.
Can you back up the pin holes with a piece of copper?
Not sure how many pinholes you have but for longevity I have found it is better to just cut the spots out until you get to some good metal and weld in a patch. I was going to weld up some pinholes on my grill and found that by the time you get the out of the thin spots and finally get the hole filled you have welded more than if you had done a patch. Its still up to you though. If you only have a few spots to do then fill away. I usually run C25 at 18psi for your gas question.
