    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on.
    Thanks!
OH Misc Parts
Status
Not open for further replies.
Tedster100
Chairman of the Bored
Ford 9" rear end,drum brakes, and all new brake cylinders, pads and all new hardware with less than 500 miles on them. The 9" is a solid housing but does have a seal leaking on the driver's side and at the pinion. It has a bracket welded on the top for a traction bar link. The gears went on the original axle I had so I picked up a complete used third member with the 3.50 gears to get me by until I was ready to swap my new axles in. I have axle bearings and seals that I believe are the correct ones that were purchased long ago. They will go with the axle. If it were me, I'd go through the axle and replace the bearings and seals before re-installing. It's solid and would run fine as-is with just the drives side seal, but it would drip once in a while from the pinon.
I also have:
Stock set of rear leaf springs
Newer stock C-bushings and track arm bushings barely used
Coil cups and retainers, the lower coil retainers are rough but the cups are good.
2-1/2" lift blocks for stock leaf springs, with offset pins and 6 degrees built in.
U-bolts & plates for stock springs with 2-1/2" block, would probably fit an 11 pack set.
Removable window frames (no vent windows or hardware)
Open to offers, prefer not to ship the big stuff if I don't have to.
Status
