73stallion
okay, i'm stumped. david has a '73 bronco with a 351 cleveland in it. the #7 cylinder has a misfire. i ran a compression check, all cylinders are between 170 and 185 lbs compression, #7 has 175. the cam lobes are not flat. it's getting spark (we put a spark plug on the fender, grounded it, it's sparking, but it looks weak). plug wires have been changed, and the plug has been changed 4 times. but still, the #7 cylinder is not firing.
i've had several people say that the 351c does NOT have the same firing order as a 351w, is this true? every website i've looked at says it's supposed to be 1-3-7-2-6-5-4-8. it has a MSD 6A box, blaster coil, and 8580 distributor.
i'm open to any ideas, i'm at a loss.?:?
