Actually in this case they do! T into the vent line for your return line. The feed to engine depends on what pump system you are going to use.... Just a high? High and Low? High with a resevoir?
I went with a large spin on fram fuel filter from summit racing. Then into a red low pressure holley electric. Then into a f-150 hi pressure pump.
The tank does not need to be modded in any way if you use a method close to this.
Filler neck vent hose, cut it a few inches from the tank and insert a "T". I think it is a 1/2" hose so get a 1/2" brass T and put 2 ea. 1/2" combination nipples (1/2"NPT X 1/2" hose) and 1 ea. 1/2"NPT X 3/8" hose comb. nipple (for the return line).
