the mojave heater is a great alternative to the stock setup. i used one on my 72. make sure you get the plenum that they sell with it so you can hook up your defrost. they have a great fan and motor. they are inexpensive and pretty compact too.
If you have your stock heater you can rebuild it - new seals, new heater core and install a chevy blower motor with a bigger squirrel cage. The result will melt your face off. Litterally.
My Bronco did not come with a stock heater. I have spent a lot of time and money with the ^ seal kit, paint, chevy motor, chevy cage, etc. If I had to do it again, I would go with the Heater Craft 201.
I have a Mojave in my bronco mounted under radio between trans hump and the dash.. It gets uncomfortably hot if you keep it on high. I was plowing w/ it last winter in jeans and a light hoodie while it was 10 degrees out and hand to keep a window cracked.
