Last night I could focus on a few small things and got sucked into fixing the headlights.
The wiring was trashed from having a plow integrated into it some time ago - the driver side plug was long gone and the pass side was in shambles. I ordered a set of headlight pigtails for my other project (that hasn't been touched in years) and I have a pile of relays and a ton of wire - relay harness time!
I ran 12ga power and grounds off the battery to the relays and wired up the hi and low beams to my foot switch. I picked up a pair of new lights from the auto parts store and did some night wheeling in the back yard! I was whipping shitties on the pond in 3rd gear high range for some time and when I came to a stop the rear tires were steaming ;D Aparently I know how to make really balanced drive shafts as I had the tires spinning over 85MPH when I was doing circles vibration free!
After that excitement I headed back into the garage to fix another issue I've been dealing with - no interior lights. Now my stock gauge doesn't read anything anymore - 4G means no ammeter, no temp gauge as I run a mechanical - the same for oil. I swapped to a fuel cell and I've got no speedo, but it would be nice if it illuminated. I replaced a few blown fuses and got it to light up, but it stopped after the dimmer switch started showing sparks down. I think it's toast
I did get a dome light installed - I bought a literal rope of 4 pod LED lights and I installed one off the wiper motor bracket pointing down and tied into the dome light wiring that I'm not using as I don't run a wiper cover. It's silly bright - perfect.
