[quote author=jtcamp link=board=5;threadid=8278;start=0#58650 date=1029974111]<br>I have a 74 with the BC 4.5 coils and f150 tie rod over conversion. After replacing everything, including the steering box I still have wandering problems. I think that more caster might cure the problem, but I have heard that the radius arm drop brackes aren't worth it. Are there some caster adjustment cams that can be installed in the knuckles? Has anyone else had problems with wandering with lifts over 3.5 and stock radius arms? Also I have the 7 degree c bushings and correct toe-in. Help me fix this problem. The truck has been down for 3 MONTHS. Thank you in advance..<br><br>John<br>[/quote]<br>Just curious, does everything include the ball joints, if not check them, my E.B. rode terrible with the drop down brackets & 2^ c-bushings with 4.5" coils and when I removed the drop brackets for better trail clearance and went to the 7^ c-bushings I also replaced my ball joints a short time later, made all the difference in the world, people who drive it often comment on how it drives like a car.<br>When you had the front end aligned did you get readings on everything, if so what was your caster and for the heck of it what was the camber?<br>Good luck, Francois.
