Mounting 1/4 thick Rock Ski's
JeepGuy
Getting close to that point in the rebuild. I purchased the 1/4 thick rock ski's from WH. They provide sheet metal screws to mount these 40 lbs ski's.
Those of you that have installed them, do the sheet metal screws hold up against actual impact with Rocks? Or should I be plug welding these things to the side of the Bronco? On the very front and rear I can use a nut and bolt... but the actual rocker portion under the door that would not be possible due to the inner rocker panel?
JSBX
I have the ones from Duff. They use 3/8 nutserts in the outside of the rocker panel near the top and 1" flat bar along the inside bottom lip with nuts welded to the flat bar. There is a you tube video on how to install them. May give you some ideas to help with your install.
SteveL
Huge chevy guy
Hawthorne ca
I got mine from bc years ago. They come with beefy stainless sheetmetal screws. I havent had any problems with em. Theyve been run into a few times and didnt budge. For instal chuck recommended using a tranny jack to get em up real tight on the rocker then screwing em down.
nickgp
I’ve used nut serts on three sets. Definitely better than just screwing into thin sheet metal. A block of wood and a floor jack are a must for the install.
nickgp
A few other tips. I like to use stainless button head Allen bolts with a dab of anti seize. If your going to do a lot of nut serts in the future, I recommend the larger, two handed style tool to set larger and multiple nut certs efficiently.
69 Red Bronco
I have the WH rock skis mounted using their hardware. Came down super hard on a few rocks last season and they held up ok. Nothing fell off or broke, definitely protected the body. The only issue i had was some of the screws coming loose. A few minutes with the screw driver fixed that.
