Okay, been trying to finish up the wiring and I have a few questions. Centech harness is installed and I've started reworking the Mustang harness.
I've created a common ground and wired the power circuits per Ryan's website. I do not know what to do with these wires.
Centech Harness:
IGN PWR
COIL+
Choke (I guess this can be removed)
Idle Sol
Dist Mod
Mustang Harness
Manual Transmission Signal Return (I have an auto...Remove?)
Low Oil (Remove?)
12v Start for TFI
NDS PIN 30
Ground for PIN 30 (Am I over thinking this one?)
Fuel ON (this is coming from the computer. Is it the switch PWR for the fuel relay?)
Also, I only have 2 coil wires coming from the harness but my coil has 4 connections on the pigtail.
Centech Harness:
IGN PWR
COIL+
Idle Sol
Dist Mod
Mustang Harness
Low Oil (Remove?)
12v Start for TFI
NDS PIN 30
