    Discuss it more here:
  • The Classifieds forum is a place to buy and sell, not an open forum for people to give their opinions on Bronco values. Unless the seller specifically asks for help on pricing, please don't critique quality or asking price. If you're not interested then move on.
    Thanks!
SOLD Mustang EFI Mass Air Harness
Status
Not open for further replies.
brianstrange
I have a couple of stock Mustang EFI harnesses that I plan on setting up for easy install. It will have all the connectors for the Air pump and emissions, as well as the Mustang AC compressor and related items still on it, I will mark all wires to the fuel pump and VSS, and can include a wire loop so you can install an inertia switch if you desire. The layout will be similar to mustang, I can try to position the firewall grommet to your liking, and have the 02 sensors drop from the center rear of the engine. The power will be protected by fusible links, or you can add your own fuse block. If you want, I can strip the extra wires from the harness for an additional charge.
You will need to hook up the following
1) 12 V + Start
2) 12 V + Run (not the resistance wire from the coil)
3) 2 grounds
4) Fuel pump power feed
5) 2 VSS wires
6) Positive terminal at the battery or solenoid
7) oil pressure and coolant temp (optional, you can keep the original Bronco one if you like)
I will take care of the relays etc.....
fordguy
I have an intake, maf and some other stuff I can help someone out with if they want to go with brian's harness. I can get really cheap on these parts, I am going explorer. sorry not trying to hijack, trying to help sell your harness':)
AzDesert73
Yuma
Sorry I'm on tapatalk, and it doesn't show the price. Can you find out how much shipping would be to 85365?
Status
