bknbronco
Been in the garage "broncoing" all week again. Filed off the arms on the turn signal canceling arms. Its a fine line between not enough and too far. The roll pins would push to hard and cause the blinker lever to go to the other side rather than shutting off. http://www.stratadrome.com/bronco/steering.htm
Mounted the dual doetsch DT3000 shocks all around (3403's in the front and 3368's in the rear). Also installed my 10deg shims in the rear axle. While i was back there i took a few minutes to hook up the e-brake cables to the drums (someday soon i will hook up the front cable and the brackets and lever).
Later that evening i got bored and made a glovebox from cardboard and covered it in black duct tape.
The next day i spent some time aligning the doors and shimming the body mounts. I also dropped off my windshield pattern.
Yesterday i picked up my glass i had cut for the windshield and primed it and urethaned it in the frame. http://classicbroncos.com/forums/showthread.php?t=205788 I also got my DOM tubes back from the machine shop. My friend cut the tubes to length and added a weld bevel. He also cut a wrench slot in the weld in inserts.
Today i preped the hood for paint, as well as a bunch of other pieces for the tailgate, and the hood latches and such. I finally got my inserts welded in the DOM for the tie rod and drag link, and preped them and the TRE for paint.
Tomarrow looks like ill prep the grill, and tailgate again. Run to the store for some paint supplies, and make sure im ready to shoot sealer.
