My rock skis are on !
got-broncos
I dont weld so I had it done. I had the end caps welded on for 25$. The skis were welded on for 65$, good deals on both. All I need to do is paint. ;D
got-broncos
got-broncos
Did you purchase those skis or did you fab them? They look realy good!
They are 2"x6" 3/16ths tube steel. There are some good theads to walk you through it. I cut them to length and cut end caps. I also cut the rockers off. I had the end caps welded on,and I put the grinder to them. I only have $200 and my time in them. Thanks for the complements guys.
greatguy57078
Man I really love that look. The rockers are toast on my '74, and I am for sure going to go this direction. Very nice looking job done there Terry!
NGABronco
Always Learning
N. GA now South Carolina
Hey got, those look great!! Sure glad you posted the finished pics. I right behind you with mine and I was wondering how you finished the ends.
It looks like a 45 degree slant??;D ;D
bax
Old Member
I like them. Once you cut the rocker away and notch out for the tubing, do you add more structure to weld to or do you just weld to the body sheet-metal. Is it stitch welded on, sealed with some seam sealer and painted.
Bax
got-broncos
got-broncos
I followed the lines of the flares. The front was close to 45,the back closer to 70 degrees. I think alot of people do 45s. I had them run the welds all the way around,but not the front fenders. No need for seam sealer. The welds look pretty good. I cut the end caps to fit the inside dimensions. That way I could round out the ends with a grinder. They are welded to the tub only. Thanks agian for the complements.
carhauler
Harford Co. MD
Those look great. I have a few questions. I'd like to do this to mine as well. Did you just weld the 2x6 to the notch you cut in the outer rocker? Are there any supports welded to the frame? If so, did you cut the inner rocker to get to the frame? Thanks in advance.
KyleQ
Looks great - I plan on doing the same exact thing... and I plan on using them as well!
