Name this Carb
C
CincoBravo
Oxford, MS
Venturi Size
Now that I've confirmed the venturi size to be 1.21, I've read that this size venturi wasn't typically used on a 302. Does this being a 1.21 definitively rule out this carb as being original to the vehicle? My Bronco is a '77.
Skytrooper15
Tuscaloosa,Al
I have a 1.21 venturi carb on my stock 302 and it runs great with it and you are correct most if not all factory 289s and 302s came with a 1.08.If you need a part number for a kit this is a Hygrade part number 586 available at most auto parts stores.It doesn't come with the choke pull off but a good counterman will find you that since it is separate from the kit.It is an easy carburetor to put the kit in just remember to drop the check ball and counter weight in under the needle and seat.Just buy a can of carb cleaner and be careful with that stuff and keep eyes away from it with googles and the instructions are also in the box and easy to follow.Good luck and get that Bronco back to rolling whether it be the hiway or the trails and mud.Forgot to answer your question about the 1.21 venturi size,mine was a ford dealer replacement bought in the late 80s to replace the worn out 1.08 that was original to my 70 model.
pipeline010
ya any generic kit will work on your carb rebuild. When I did mine it had a bunch of extra stuff in it for other carbs. Whole kit at big box local was like 20 bucks and came with a new power valve, too.
GP Sorenson part #96-215 was what I got.
Rustytruck
Its not origional, carb tag missing. With spacer egr I would guess its a 1973. Ford put the egr seperate on the intake in 1974. What is the part number cast on the intake.
C
CincoBravo
Oxford, MS
Pic of the number etched on the carb casting
Skytrooper15
Tuscaloosa,Al
The 2MFE tells me you have a 72 year carb which will work on your Bronco just fine.A couple of members said the correct carb would be a 2150-2V which is...correct.If you want a 2150 to be correct for the year Bronco try dropping Bronconut1 a PM and see if he has one.
pipeline010
Delconick may be a good place to search too. He carried a 1.08 venturi for a 69 2100. Oddly specific part and I had it in 2 days.
Skytrooper15
Tuscaloosa,Al
Does the carburetor you have on your Bronco now work?Then keep it and use it.Do you want the Bronco to have a correct carburetor for the year model then by all means find a 2150.If you go the new carburetor route the casting won't be an original 2150 because most of the rebuilt carbs are cast in china.
C
CincoBravo
Oxford, MS
It was working, but running rich. Thought I'd rebuild it while I had it off. It's nasty, rusty, and part of it is literally held together with bailing wire. Then realized it's not even the right carb for my engine (1.21 vs 1.08), so am now considering if I shouldn't just start over with a carb more suited to the 302 rather than spend time and money on the 1.21.
C
CincoBravo
Oxford, MS
Finally was able to get the number you asked about. It is: EODE-9425-AB
I now know enough to know this isn't original either, and I don't think it was intended to host the carburetor that's been on it either (right?). One question about this intake-- behind where the carb mounts there is a steel plate that seems to be blocking off an opening that was cast into the intake. There are threaded studs coming out of it and the plate is bolted onto them.
Does anyone know what that opening was originally for?
Justafordguy
That opening in the intake behind the carb with the plate over it was for the EGR valve.
