- Oct 11, 2007
- 375
I m thinking of buying a high pinion 78/79 Dana 44. I would narrow the long side 6 inches.
I’ve been looking on here and reading what ever I can find but I have a question.
For anyone that’s used one of these axles, is the castor numbers any better than the original bronco Dana 44? I have a 77 44 in my 66 now, 3.5 duff coils 7degree bushings stock radius arms. I’ll admit I should definitely re measure but the readings I got on my angle finder was 1 degree positive castor with all of the above compontants. It doesn’t drive good at all. I’m going to order the duff dual sport steering but need to figure out what axle I will be running first. I have to build another axle for this 66 at some point anyway and I have found this high pinion 44 and thought possibly it will have better castor numbers and I won’t need to spend extra money on a set of long arms right now. Can anyone help me out with this??
I also already have a 73 bronco housing I could cut the outer c’s and use but at some point the bearing caps have been lost. Not really sure if can get away with using another set of caps as I’m pretty sure the they were machined to that housing. Anyone have any info on this also? Thanks for any
Help.
Help.
