jetsg4
i know there wont be any help out there for this, but maybe some tips for troubleshooting electrical problems.
History:
the previous owner, in his infinite wisdom, put a "hot" switch in next to the ignition switch. it acts as the run position does on the stock ignition. i've been having some problems having to hold the gas open to get it to start, which i got pointed towards it flooding. upon suggestions i checked the fuel pump, ok, and checked the float for sticking, which there was a bit of dirt in the bowl, but everything looked fine. bringing us to the new problem.
i stick it all back together, and turn the starter over a few times. then the wonderful melting wire smell starts. the negative side of the starter solenoid was smoking, there is a wire nut in the middle of the hot wire running to the run switch which was smoking & melting the wire insulation, and all of the wires in the run swich loop we hot &/or smoking.
the hits just keep on coming.
History:
