Need a few frame measurements:
Archbronco
Hey all,
Getting some data for the metal surgery on my frame. I need the following measurements (with the hope that these distances are the same within the tolerance).
Bottom of frame passenger side:
Oval hole (furthest point of hole toward rear of frame) nearest the crossmember to the end of the top & bottom frame horn
Oval hole nearest point toward front of frame to end of frame horn (top and bottom)
Top of Frame passenger side:
Oval hole (furtherest point to rear of frame) nearest to rear crossmember to top and bottom of frame horn
Top of Frame Driver side oval hole nearest crossmember to top and bottom frame horn
Top of frame passenger side oval hole closest to front frame horn. Furthest point forward to the frame horn top and bottom.
Thanks a ton for those that can help, I owe you a few beers!
Josh
1969
I don’t have my frame handy at the moment but this may help you IMG_3401.jpeg
catfan
Are the oval holes for anything, I have seen the spare tire cable hooked to the rear one but the
others nothing.
Archbronco
Archbronco
others nothing.
I think they are just for water/dirt to escape. I’m not even sure they are static points on every frame.
