Uncut1970
- May 8, 2017
- 163
I need help diagnosing and addressing some issues I am having with my old Bronco. I started working on It as a rolling chassis in 2017 and have her running pretty good now. just a few lingering issues I want to get fixed.
I installed the TBP disk brake kit (disk front/drum rear) Wilwood adjustable proportioning valve, all new e-brake hardware, and the WH power brake kit. I also installed a new centech harness, Classic Air A/C, and power streering.... along with a bunch of other stuff under the hood that proves my ignorance and inexperience as a mechanic. All of this to say, there could be multiple causes for the issues I’m having. This was/is my first real project.
1 - Brakes: it stops when I press the brake pedal, but I think it is all front brakes. Also, pressing my e-brake cable does nothing. It seems it about 60lbs of force to compress the e-brake cable with that new spring underneath but still is not to engaging.
2) I installed the TBP wood and SS steering wheel with center horn button. If I tough the center button and the bezel around the button at the same time, the horn goes off without compressing the button.
2.B) this one may have something to do with the above, but my gauge cluster lights (new from Classy Gauges) stopped working the same time i replaced my passenger side rear running light bulb.
2.C) my brake warning light on the dash has never worked
2.D) my turn signals flash at an accelerated pace, which I know usually suggests a short.
3) I installed a new 3.5 suspension from TBP (at least that’s what the PO said), it was in a big cardboard box. Problem is, it is stiff as hell. It hasn’t broken in at all and I really want to have a more comfortable ride. It is incredibly stiff right now; what is the most economical way to start addressing this?
