pcf_mark
- Jun 11, 2010
- 3,646
I have oversized tires on 17" rims on my stock height, no lift original Bronco. The fit great and look even greater! I had to trim a piece of the front left inner wheel well. The problem I am having is the right side rear rubs very slightly when the wheel travel up. On the driver side I have 3/8 of an inch clearance. On the passenger side I have .050! When things move around the tire just barely makes contact but it makes a terrible noise!
I loosened all the rear spring attachment hardware and attempted to shove the axle over but this did not get me anything.
I need .125" I think to make this fit perfectly (I never off road).
Option 1: use a cut off wheel and trim .125 off the inner lip
Option 2: can I loosen the body bolts and shift the body over???
Option 3: 1" body lift. This would be more work than I want for a little bit of rubbing
