nik
Alright so I took the whole case apart pretty much with no hiccups. My problem is I only knocked out 2 roll pins (the ones that hold the shifter rails and forks together), but when I got everything out of the case, there were 3 roll pins sitting in the bottom.
I used this diagram
http://www.nitpik.com/dan/truck/specs/np205/transfer_case.html
to help identify what the 3rd one goes to. The only other pin I see is on the rear output shaft (2183 in the diagram) but there is definitely no way a pin fell out of there. The only other place I see where a roll pin might go is on the Idler Shaft. There is a sleeve that slides over the shaft between the bearings which has a hole that lines up with a hole on the shaft itself. The thing thats throwing me off is it's not shown in the schematic.
Anybody have any ideas?
Thanks in advance,
Nik
I used this diagram
Thanks in advance,
Nik
