bronco_46254
I'm tired of the 2150 and its worn butterfly shaft causing me idles that are approximate at best. Its a crap shoot between 650 and 1100 RPM and any stop light even with heavy duty return springs. SO...I would like to put on a Holley 2-bbl from Summit but have some questions before I buy one for my stock '75 302:
1. 350 or 500 cfm. Summit lists both, but with a completely stock 302, which is correct?
2. Is is a direct bolt on? The base of the 2150 looks similar to a holley 2-bbl, but the Ford base plate has to cover the emissions port in the manifold.
3. Will the throttle and kickdown linkage hook directly up? They come with Kickdown and universal linkage, so it looks to me like it will.
4. Will my Air Cleaner fit under the hood? I have a chrome low profle open element from JBG and it just barely touches the hood with the 2150.
5. Are stock jets sufficient? I know they come somewhat dialed in, but if I should do an immediate change, what jet size do I need to have on hand? Again, completely stock '75 302
Thanks everyone!! Love the board and more importanty, my Bronco!!
Chris
Chris
