- Nov 3, 2009
- 1,205
I rebuilt and installed a weber carb on my 200 six with an adapter from Langdon's Stovebolt. I drove it for the first time today and it runs good, but when I got home I shut if off and checked it out and notice gas dripping from it onto the hot manifold (not good). Anyway, if you pull the vaccuum advance line off gas leaks out of it and it seems to be leaking around the butterfly shafts. After a few minutes, it quit dripping. I can also hear a kind of gurgling noise coming from it like it is bleading off pressure or draining. Do you think the fuel pressure is to high? Need some advice, the carb was used, do i need to just buy a new one or what? It helped the power a good bit over the one barrel.
thanks.
thanks.
