I have a 72 Bronco that has a Holley 2V mechanical choke carb. I rebuilt the carb using a rebuild kit (gaskets and all the other parts that come with the kit). The problem I have is that when it starts up it idles fine. I pull the choke to start and then open once it starts.
When start driving it and putting it under any kind of load, it wants to stumble some or some times when I come to a stop it will die altogether.
I have replaced the mechanical fuel pump over the last couple of years, but was needing to know the most likely culprit when it came to this issue.
