clintonvillian
For starters let me say that I have no clue what has been done to this motor. I'm trying to figure out what the PO installed.
It came with an aluminum "Ford" 4 barrel intake, 4180 Carb, E7 or E7TE heads.
I checked the lift at the pushrod, it measures .210", at the intake valve it measures .340". Seems to be a stock Cam, right?
Compression is even across all cylinders.
At 6 degrees timing, it is pulling 7 inHG. I advanced it to 12 degrees, and it is pulling 13 inHG.
Now Monday evening I advanced the timing to around 20 degrees, and had it tuned pretty decent. Still only pulling 13-14 inHG. Some guys reccomended I disconnect the PCV valve (it is aftermarket) and check readings at factory timing. This is where the issues started happening. I couldn't get the hose off of the pcv valve or off the nipple on the carb spacer. So I just pulled the PCV out of the valve cover...engine died immediately. tried to restart it, and nothing.
Pushed it back into the cover, and it starts and idles fine. So I think okay I will pull the hose off. Pulled the hose off the PCV and plugged it. Pulled the PCV out of the valve cover.
Engine starts, sputters surges really hard, starts knocking. I grab the test light, and put it on the balancer. The vacuum advance kicked in and timing is probably 40-50 degrees. At this time, I panic and grab the distributor and twist it back down...a little to fast and retard the timing below 0 degrees and cut the ignition. As this is going on I look up and fuel is pouring out of the accelerator pump.
I cleaned everything up, plugged the PCV back in, set everything back to where I had it the night before, fires right up. I now have a small leak at the accelerator pump, that sprays fuel when I hit it. But the engine runs....except now I think I have a permanent knock near cylinder 8.
What are your all's thoughts?
No vacuum leaks (that I can find). Would a small leak at the accelerator pump cause this? Or is there maybe an internal vacuum leak somewhere? I just put new intake manifold gaskets on, as well as the carb rebuild.
