Having trouble with Uncle Sam’s sniffer test. The whole drive train is 2yrs old, with only 2000 miles. Passed fine last two years, nothings changed. I run 2 big Cats all the time. The A9P computer has a stock tune in it.
I retarded the timing a few degrees and filled the tank with 91 (I normally run a little octane boost in the warm/hot/scoring months only) Interestingly, it passed idle and failed the loaded reading.
HC load = 261/250 Fail
CO load = 5.70/1.50 Fail
HC idle = 196/250 Pass
CO idle = 0.72/2.00 Pass
So I pulled 4 lbs of fuel out (44 down to 40) and advanced the timing half way back to normal (2 deg or so). The TFS intake sucks a little oil and I get a puff of smoke when I start it after sitting for awhile, so I ran it down the freeway at 3500 rpm awhile before pulling into the emissions test house, hoping to burn out any contaminates. Now is passes loaded and fails idle.
HC load = 179/250 Pass
CO load = 1.40/1.50 Pass
HC idle = 648/250 Fail
CO idle = 3.98/2.00 Fail
Any ideas for round 3?
