RJGarza
Ok so here's the deal. I have a '66 bronco that I'm wanting to lift 3.5" and I'm currently piecing together a lift kit. I have the rear springs already taken care of but I need to get my front suspension lift ordered here pretty soon. I don't know if it will make a difference but I plan on using the front and rear axles off a '74 bronco along with the factory power steering box off a '74 bronco as well. As of right now I have a set of Duff 10 pack leaf springs for the rear. I'm not exactly too sure what all is needed for the front as this is my first bronco build and I'm not too familiar with the front coil suspension. I've done a little bit of online searching and came up with a list of things that I believe will be needed to complete the front suspension. I'll go ahead and type down everything I came up with but please feel free to throw out any advice or even add something else to my list if it's necessary. This bronco will be street driven 95% of the time so I don't need anything too crazy although I do plan on doing some trail riding every now and then. I plan on running 33" tires, MAYBE 35" tires. Before anyone mentions it, I know the '66 frame shock mounts won't match up with the '74 axle shock mounts. I would love to keep the original '66 frame shock mounts so I'm going to order new axle shock mounts. I plan on waiting to order shocks. My bronco is completely dissasembled and I'm trying to finish the chassis so I can set the tub on the frame and start doing body work. I know I'll need extended brake lines but I plan on having them made local. Again, please feel free to add anything I may have left out. Thank you in advance.
- 3.5" coil springs
- c bushing, trac bar bushing & radius arm bushing kit
- drop pitman arm
- adjustable trac bar (do I need this or can I get away with a drop bracket?)
- rear leaf shackle bushing kit
- 10° radius arm bushing kit
- rear lower shock mounts
- 3.5" coil springs
- drop pitman arm
