Rmally
Hey Folks,
I am having some major confusion over the fuel tanks....main and aux.
First of all on the left side dash I have a fuel selector switch for the gauge. It reads full when its on the aux tank but is pegged to empty when switched to the main tank.........and the main tank is FULL.
Next, is the fuel tank selector switch on the floor printed upside down for main and aux? The reason I ask is this. I took the bronco out today and noticed my fuel gauge read empty in aux and main, previously it was at 1/4 tank on aux but has been at paint shop so I'm sure they ran it low. I headed straight for gas station and the bronco died on me three times in 2 miles. I switched tanks....no good. I rolled it down the hill and when I was level it fired back up and I coasted into gas station.
I tried to fill up rear tank (that's the main right?) but it was already full. So then I moved to the forward tank (aux right?) and it was empty, put about 6-7gallons in it and it started right up. Also the fuel gauge read FULL. I switched back over to the main tank and it started sputtering.
So, I left the dash selector on aux (gauge reads full) and the floor selector switch appears to also be on aux and it ran fine all the way home.
This may be a stupid question but when I lean over to look at the floor selector switch aux is to the left and main is to the right...is that correct or is my plate upside down?
It appears I'm only running on aux, how can I get the main tank back online?
Let me know if you need further info or photos.
FYI...71 model
Many Thanks,
Randy
PS...pictures of the new paint coming soon, will start a new thread when I can get some photos and trim back on.
FYI...71 model
Many Thanks,
Randy
