Hello. I've been a member here for years but since my Bronco project(s) got moved down my to-do list for many of those years I haven't been reading or posting. Hopefully I will be able to stay on top of this one for a while.
My problem right now is with a 1973 wagon with the 302 V8 and 3-speed manual. I mounted an electric fuel pump and it seems to work well; but since I didn't know any better I just ran the hot wire to the battery for testing it out.
Now that I know it works I would like to wire this a little better. I have seen a lot of talk about inertia switches and oil pressure switches in other posts as well as installing a "security" switch. All great ideas. And when I get around to redoing all the wiring I will likely implement some of them.
In the meantime I would like to just wire this pump in so that it only runs when the key is turned to "Run" or "Start" positions. Where, physically, is it best to make that connection? At the ignition switch? Somewhere else?
Looking at this wiring diagram from Seabiscuit (http://seabiscuit68.tripod.com/images/73-74_06-11_color.gif) it appears there is a thing called a "Constant Voltage Unit" that gets wired to the "Run" terminal of the ignition switch. Is this a good place to connect the electric fuel pump? Where do I find that physically on the truck?
Is there a fused circuit I could patch this into that would be a better choice?
The pump I installed is made by Airtex and the instructions simply say "Connect the pump power wire (+) to a power supply that is controlled by the ignition switch."
All help is appreciated. My plan is to do a rather thorough rebuild next year. I just need this running soon since it is my plow truck for the winter.
Thanks!
Gould
Thanks!
Gould
