need info on rear disk breaks for a 77
I Am Trying To Figure Out What Type Of Disk Brake To Put On The Back Brakes Conversion Kit Or A Mark Kit Dont Understand The Pros And Cons Of Either
TOFIC
Bronco Wrencher and Fixer
Redcliff Alberta
I did the 78 Lincloln Mark brakes on mine.
Another alternative is the 73 Tbird rear discs
The conversion depends on the rear end of your Bronco.
Small bearing is the 73 type, large bearing is the Lincoln type
Read my rant on the left<<
TOFIC
thegreatjustino
Red Head Grease Monkey
Stockton, CA
I used '77 (I believe) Mark VII brakes and have no problems with them. There is some machine work involved, but most of it was done by the guy I bought the parts from.
gravy
Parsippany
I am running the explorer set up- It bolts onto the large bearing 9in with no mods- it has the parking break built in. You just need to drill the rotors- It works great so far- check WH, they sell the parts also including the ebrake cables
