Need pic of DUI on stock 302 with air filter too
76moneypit
Lander, Wyoming
Howdy,
Just received my one wire DUI and live wires from performance distributor and I am having a heck of a time getting the spark plug wires to the correct post on the dizzy. (too short or too long)
I think the wires are not correctly cut to length.
I've even tried to move the wires around to see if I can get the correct firing order. Starting number one wire(number one cylinder) on all posts on the distributor.
anybody got a pic that also includes air filter?
Is this so simple that I'm looking beyond it????
THANKS
cgbexec
Naples, FL
I always just do it one wire at a time trying to find the best length wire possible. At the end you may end up with one wire that is too short or too long. Then I just swap out a couple wires to make it look as neat as possible.
Thanks,
Chris
76moneypit
Lander, Wyoming
just talked with the guys at performance distributor. I have the wrong wires. They are sending the correct ones.
I thought something was wrong....
OsideDave
What type of air cleaner housing are you using? My air cleaner (aftermarket Summit brand, drop down style) is hitting plug wires/distributor cap.
cupcake
I have a DUI amd a 14 inch k&n. It took alittle modding of the element and the base but here is a pic. Its not in a bronco but same deal
