I'm doing an install of a pre-77 aux tank into a '77. I bought the tank from one guy and the '77 filler neck/door form someone else. Now I need to connect the two. Seems as if the filler tube for the '77 is larger than the earlier aux tank, which is really no problem...but finding a supplier of flexible 2-1/8 fuel hose is. Napa only has non-flexible.
Jeffs Bronco Graveyard advertises aux tank filler hose for 66-76; what's the difference here? Do you think I could use that?
