just to echo what everyone else has said, mig setup is the most important thing for a begining welder. making sure your area is clean (bare metal works best), make sure your ground is good (once again bare metal works best plus try and get your ground as close to your work as possible.), if your running gas makre sure it is set correctly, and I agree with everyone else go with smaller wire, it will make things much easier. when your getting your wire pickup up a cheap metal thickness guage will help with your setup alot. All welders are diffrent so you may have to adjust your settings a bit compared to whats on the lid, try youtube look up spot welds, lap welds, and butt welds. good luck ;D
