Did the manufacturer miss some holes? The large oval hole, I presume is for the center of the assembly, but no bolt holes? can someone post a photo of the assembly mounted correctly?
Here’s a pic of my firewall with nothing attached ..the accelerator pedal assembly doesn’t overlap with the brake pedal assembly they just but up to each other ..oops need to rotate pic 90 degrees clockwise
There is a difference in location of the pedal between 72 and later ones that had carpet on the floor. The gas pedal sits closer io the column on the later ones that have carpet on the floor from the factory. The pedal is mounted closer to the column so the pedal doesn't rub on the carpet on the tunnel. Insulation and carpet is the culprit. I added both to my 72. I was ready to move the gas pedal on the bracket until I noticed the difference between the brackets. Sometimes you get lucky when you have an inventory of parts you know you will never use.
