The orange wire (30) goes to the battery, the blue wire (87) goes to the fuel pump. Green wire (85) is ground and red wire (86) goes to ignition 12v. Make sure the blue wire is in socket 87 and not 87a, otherwise the fuel pump will always be on, until you turn the key, shutting it off. 87 is the normally open circuit, that's what you need.
